Originally Posted by firebirdguy
you're welcome.
yes they are designed to be about 10% stiffer valving & 10% stiffer springs than stock SR5 shocks.
they do lift the front some, mine was about 2" above where it was with worn shocks/springs, so probably closer to 1" higher than they were when new.
if the shocks were provided by the shop, tell then you would like the UPC codes from the box & a receipt for the rebate. if you bought them then you should have those. just dont let teh shop get the warranty unless they discounted the price for you upfront. its a free 60 bucks!
Interesting info, thanks for sharing. Just to clarify, you're talking about the Struts Plus system which uses the standard OEM replacement Excel-G shocks and pre-assembled springs. Did you look into the Gas-a-Just shocks for the front?
