Originally Posted by mteolus
BEFORE and AFTER
And just a note, the section that goes between the back window and the rear side window (can't remember what that's called) that has the SR5, or TRD Off-Road, or the TRD PRO, you will have to cut the piece in two and remove a section so that the magnet doesn't go over it. I found out the hard way. Had to shag it off a highway.
I'm also checking to see if there is anything that can be done to protect the plastic fenders such as Clear Bra or something like that. I'll let you know. I may just put a piece of tape on each of the door handles to protect them if I get into some heavy brush. Clear Bra may work for the fenders but not sure if anyone would install just them and not sure about the cost either.
Sweet rig! Let us know how the armor holds up and how well it protects on the trails. Also, did you have any rubbing with your Ray10-KO2s? I have a similar setup with a 2.5” lift about to be installed. Want to make sure no BMC is required.
