Originally Posted by firebirdguy
depending on miles & how it was used prior to you owning it, rear springs are probably fine, unless it was used for towing or abused off road. mine had 145k on it & the rear springs felt fine & the rear sits up just like other stock 4runners i see whicjh is pretty high as is.... so i left mine alone. you can buy new springs if you want but probably not needed. moogs are good quality though.
the front kybs lifter the front about 2" from what it was & im sure it was sagged at least 1" from stock. so the kybs added about 1" over stock after about 1000 miles to settle in. looks close to level & if i want more up front i can add a spacer... but i dont off road so not worried about a lift.
i did all the work myself too & was pretty easy, hardest part was undoing the xreas connections. had to cut the rear top bolts on the shocks with a sawzall since the flex in the shock makes it hard to get the torque needed on the bolt. i plan to get the poly sway bar bushings too, my front end links looked & felt fine so i reused them.
You say the KYB plus front shock provides a little bit of lift from stock, could you measure from the fender opening to the center of the hub/wheel so I can compared it to mine?
I will be doing my shocks in the near future and I'm thinking of going with the KYBs and I want to compare your measurement to mine which has a 1" spacer in it at present.
