Originally Posted by DeltaWhiskey
Love the fogs, super easy install to boot. The passenger side only required removing the two bolts from the bottom and then folded the liner back and over the outer tie rod. That fog splash cover literally pops off with a minimal pull and then hinges upward to release. 2 screws on the fog, voila removal complete. Did the drivers side just by reaching up from the bottom and removing the fog light screws.
Might have taken 25 minutes total
Congrats! Lookin' good! I do have a question for you now that you have them installed. How much of an improvement are these over stock halogens? Obviously these 6000K LEDs will cast a very white beam vs the less white halogens, but do they actually help you see what's on the road much better, and also do they shine a wider beam to the sides than stock? Thanks!
