Originally Posted by STI_MECE
In my opinion, I'd do it right. Ie. Pull the head off and swap it with another. I guess ideal gas is a head that is coming off a running engine.
My 5VZ had the same problem as you. It's on cylinder 1 though. Way easier to fix if I wanna go the time sert way. But luckily for me it's been 2k miles and hasn't blown out. And I reused the insert in there too.
I'm keeping an eye out though for a good donor head. Might be worth looking around at junkyards for fresh runners showing up.
But maybe has someone here has experience with doing time serts that can speak to their longevity. To me it's a band aid solution. Swapping it cures it but leaves you open to other problems so you gotta know what your doing
Sent from my Pixel 2 XL using Tapatalk
Do you know if the head from his wrecked '98 that he mentioned will fit on his '96? I would imagine that it does.
