Originally Posted by AuSeeker
You say the KYB plus front shock provides a little bit of lift from stock, could you measure from the fender opening to the center of the hub/wheel so I can compared it to mine?
I will be doing my shocks in the near future and I'm thinking of going with the KYBs and I want to compare your measurement to mine which has a 1" spacer in it at present.
measured mine today. from center of cap to bottom of fender is 20.5". i usually measure from the ground to bottom of fender & that is 35.5" with 265/70/17 tires on stock sport rims.
hopes that helps
