Originally Posted by firebirdguy
check out "that titanium 4runner" member, he has a xreas delete pink on his profile... or do a search for xreas delete or removal. or google/youtube search for it, there are lots of threads & vids on how to do it.
the basics are, unhook each shock at the one way check valve, about 10-12" away from the connection on the shock. then remove the distribution blocks on the frame & remove all the remaining lines. the lines can stay if you dont care about it, but the main thing is to dosconnect at the check valves, with all 4 wheels off the ground. the rest is just removing the shocks themselves.
i just did this on my 08 sport & it was pretty simple, hardest aprt was the rear shock top bolt, wouldnt budge due to the flex in the shock/bushings, so i just cut it off with a sawzall.
Lol I appreciate the mention but I dont have the link, I think I know who you are talking about though. Ill try to find him and the link
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs |
5th Gen Brakes | Everything else is in the
Build Thread
