Originally Posted by Primo
So that is exactly how I have mine wired with the same components and it seems to be a no go. Not sure what else to try. Thank you for the quick reply.
Sounds like you did the same thing I did. I think you need to flip the blue and white wires.
The switch should always be able to turn the lights on when the ignition is off if you're using a basic relay setup coming off the battery. The only way around that is to get much more complicated I think.
The switch should NOT light up when the switch is off though. Mine did at first, when I switched the blue and white wires it turned off the back light on the switch. It only lights up now when the switch is on, assuming you have re-connected the black wire.
Tapping the 4th wire into the dash illumination wires will let the backlight of the switch come on with the rest of the dash lights.
