Real Name: BobH
Real Name: BobH
Installing an inverter is too expensive and too much work.
Try a test first at 12V in the garage or driveway.
Get a 12V socket and connect it directly to the battery and see if the O2 unit continues to work. If it does, then a larger wire and separate socket inside the T4 should fix it. As others stated, run the new wire directly to the battery, use a fuse and mount it in a convenient place.
