ill do that. they need to be adjusted anyway. i forgot though, which way are the e-brake adjusters turned? i know they're opposite from each other but cant remember which side turns which way?
i have the dreaded Brake/Vsc/Slip lights on (no ABS light.) unfortunately, new gas cap, new brake switch, ecu reset, and ZPC have not worked. maybe the e-brake adjustment will help as i was in there screwing around when i replaced the regular brake pads.
