Easier way to check fuel pressure
Hey everybody! Just wanted to share a easier way to check your fuel pressure. If you head down to your local pick and pull and cut off the hard fuel line that goes to the rubber fuel line and basically run "two" fuel lines with a T barb in the middle with the gauge hooked up. Make sure engine is cool, relieve your fuel pressure by loosening the fuel lines to the filter. It's a easier way to tap into the fuel system without the specially made banjo bolt fitting. I was experiencing issues with acceleration and fuel delivery. So i plumbed this in and it would hold 44lbs at idle on the gauge and fall flat and sputter during heavy acceleration. Please be careful when purging the filter and fuel lines! DO THIS AT YOUR OWN RISK! I am not held liable for any losses. Good luck and Cheers!
2000 Limited 4wd Millenium Silver Metallic, E rear locker, KYB Monomax All around, '99 tall coils up front with daystar 1" spacer, OME 890's in back, Weathertech Floor and cargo Mats, Track decal shackle Brackets, Satoshi grill mod (wahoo), Diff breather mod, 200k+ and still going strong!
