Originally Posted by dvto2
2005 4runner sport v6. 260 K. The truck was maintener by the dealer for the first 100 K and then I took over. One thing I never got to was ther power steering fluid. Last week the steering got stiff and a little jerky. I changed the fluid by sucking it out, exchanging a little at a time, until it looked clean, at least much cleaner. I exchanged almost a quart. However, the steering isn't much better. Do I need to exchange another quart, or should I be checking other things.
Since you live in a snow/rust state check the universal joint on the steering shaft, spray some penetrating lubricate on it and see if the issue improves, if it does that steering shaft portion with the universal joint needs to be replaced.
It's a common issue in rust areas after as many miles as you have on your's.
