Originally Posted by firebirdguy
the spacers will work on 4th gens... but unless they are made for xreas they wont work on xreas 4runners. reason being is that most spacers are designed to bolt into the factory locations on the top, then you just rotate the shock 180* to bolt to the spacers... with xreas you cant rotate the shock due to the fluid line that attaches to the shock.
before i knew this i bought some cheap spacers & found out they wont work with xreas, so i just bought new shocks to replace them with since most xreas systems are about shot by now on 4th gen 4runners.
ohhhhh. didn't think of that! makes sense. did yours start leaking or could you just tell a difference in handling?
