To make sure I understand what you're asking, you have the Kicker tweeters in the dash position, stock speakers in the door currently?
And you are wanting to put Focal woofers and tweeters in the doors?
If this is correct, couple more questions:
1) What Focal speaker set did you get?
2) Does this set have separate Crossovers?
If yes, then sure, you can add the Focal components to the door. You will have to drill some holes to mount the component tweeters (there's room for a tweeter above the 6X9 centerline, follow the same angle about 4" high) , and you'll need to locate a spot in the doors to mount the crossovers. Behind the armrest is an indention where there's room to sticky tape or velcro it.
Wire your stock speaker wire to the crossover, crossover to the woofer and tweeter (it's marked which wires go where), and voila.
Narat
2019 TRD ORP, Milestar Patagonia LT295/70R17, Method Trail 701 wheels, King suspension 600 sprgs, Dobinson C59-677V +400 rr sprgs, ECGS 4.56 grs, Frt E-Locker, Coastal Offroad Alu dual swing rear bmpr, CBI Alu frt bumper, SmittyBilt X20 10K Synth, Flatlink E, RCI full steel skids and sliders, DuroBumps, MetalTech RR LCA, Dual 31M/34M Northstar Batts, Blue Sea ML-ACR, LFD Offroad Bat tray, Schrockworks air pump relo brkt, ARB twin comp, Gibson exh, Infinity Component dsh and dr spkrs, Hertz HCX 165 hatch spkrs, 2x Kicker KEY 180.4 DSP amps, Kenwood TM-V71, Cobra 75 WX ST, Midland MXT275, ArcLight LEDs, XenonDepot HID low, LED High, Diode Dynamics Turn-as-Tail, Switchbacks, CaliRaised Ditch light brackets, Rigid SS Ditch lights, Stock OR wheels with 285/70R17 E GY DuraTracs, Custom drawer/sleep platform, Dometic CFX50, More lights and antennas than I can name, beer
