Real Name: Ron
Real Name: Ron
It's just above the steering gearbox, you'll see a 2-bolt coupling, a ribbed shaft coming down from it and the u-joint is toward end of that shaft. Probably can't see the u-joint, either get underneath or pull d/s front wheel.
I had the problem of stiff steering and that was it, changed shaft and nice smooth steering again.
Do service your P/s fluid though.
