Real Name: Chris
Real Name: Chris
Originally Posted by Big Daddy K
I don't know, I've used Toyota...well I assume that is what the dealer was using under Toyota Care. Then when I took over service I changed the filter cap, out of necessity as it seemed the dealer put it on with an impact gun, and used Mobil1 for 2 changes (5K each) The latest change I used Amsoil. Honestly I really don't notice any difference at this point. We'll see what it looks like in about 3K.
The tricky one seems to be transfer case fluid. The Toyota stuff can be elusive from what I have read and it's $$$.
Not sure what they use with toyotacare, I have never used that service for reasons just like you posted. Not worth the free oil changes to me, I'll do it myself and know it was done right. The 75LF transfer case fluid isn't cheap but it's cheaper than taking a chance with other fluids and possibly causing damage to your transfer case. Plus I plan on changing it every 50K along with transmission fluid which for me is every 7 years.
