Originally Posted by feelingstoned
Yeah that's what I was referring to. A lot of people are running lifts higher than mine without doing a drop bracket. I specifically didn't get it because i assumed the weight of the bumper would off set it. A lot of people are iffy about it. I'll check this drop bracket out but the toytec one is a weld on, I didnt want to do a weld on.
Sent from my SM-G975U using Tapatalk
The one I linked is weld on as well. I don't think there are any bolt on drop brackets for it. You can try an adjustable panhard bar to center your axle, but if you flex a lot you're more likely to hit a rear tire on the fender instead of tucking it due to the extra panhard bar length shifting the axle further during flex.
2000 SR5 V6 Manual 4WD
https://www.toyota-4runner.org/3rd-g...biography.html
