Real Name: Chris
Real Name: Chris
Originally Posted by Whippersnapper02
Where's the proof of this so called super secret sauce special blend of oil specifically for Toyota? Maybe there's Toyota specific gas too.
Clearly you didn't read through this thread very much. There is a link to the data sheet on Toyota oil on the very first page, post 14. Take a look at the Moly and zinc levels in the Toyota spec oil. Do your own research, since I am not going to do it for you, and look at the spec on other oils on the market. Find me another oil that has an additive package as aggressive as what is use in Toyota spec oil. This is why our engines run so much quieter and smoother when using Toyota 0W20
