Real Name: Chris
Real Name: Chris
Originally Posted by Whippersnapper02
If you're too lazy to do a little research, don't bother commenting. You clearly believe what the market tells you and you fall for their crap. That's like watching CNN and believing the mindless bullshit the spew. The link you posted is not the same weight oil and it falls way short when compared to Toyota spec oil, like incredibly short on every level, for twice the price which is hilarious. See below for a link to the Amsoil OE 0W20 Toyota crushes it as it does every other 0W20 that I have researched. This is the last link I will post for you. You will do your own research or you won't and you'll continue to be uneducated on this subject, not my problem. In reality you'll likely be just fine with any oil you run but I will stick with the oil that clearly and significantly outperforms the others.
AMSOIL Synthetic OE Sythetic SAE 0W-20 API SN/ILSAC GF-5/dexos1
