View Single Post
Old 10-16-2019, 12:05 PM
XtremeAdventurer XtremeAdventurer is offline
XtremeAdventurer is on a distinguished road
Originally Posted by eurasiaoverland View Post
Great to hear that! Could you describe in detail the symptoms you had, please?
Thanks
EO
Bought the ‘99 4Runner with 320k miles, so I knew it was going to need some work. After a ToyTec/SuperFlex lift w/ 5100’s, I started to get a lot of stability issues. New SPC UCA, new poly bushings (upper & lower on front, rear, & panhard bar), new steering gear bushings, used 2002 Tacoma steering gear, new CV’s, you name it and I replaced it.
I was also getting a vibration almost like a wheel out of balance and was starting to get a bearing noise. Suspected the front wheel bearing, so I replaced them. The stability problems were gone, but still had the vibration and noise.
Noise started around 25-30mph, vibration started to be noticeable around 60mph and was pronounced at 80. Heaving braking caused a vibration like a warped rotor, but since I had new pad & rotors (Tundra 199 upgrade) I figured it wasn’t that.
I read this thread, checked the Driver CV, and sure enough had a lot of play at the diff.
The video made sense with what I was experiencing, so I ordered the parts & puller and replaced the bearing with the bushing.
I’d say easy as that, but it was a bit of work!
XtremeAdventurer is offline   Reply With QuoteReply With Quote
