First, get the mechanical side sorted out. Make sure you have the right throttle cable bracket for your truck (needs to have the trans kick down cable attachment). Your truck will run fine without the 7th injector kit for a bit, especially if you are running the stock pulley.
Then figure out the 7th injector wiring...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
