View Single Post
Old 10-16-2019, 08:52 PM
2016 4Runner SR5's Avatar
2016 4Runner SR5 2016 4Runner SR5 is offline
Real Name: Chris
2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold
Real Name: Chris
Originally Posted by 83Mule View Post
Many oils use Moly as the heavy lifter for wear, while others prefer to use P and Z to achieve it. There is no one way to get to a reasonable Add Package. And You can have too much of an ingredient.....P and Z will foul the plug electrode at high levels even though those levels are best for the valvetrain. Just keep in mind that MORE of something isn't an indicator of better, there is a lot at play.
I agree with you on that. You really shouldn't be consuming any oil let alone enough to foul plugs but there is always a little vapor in the system. A cheap and easy way to help limit that is by installing a catch can. Mine catches mostly water but there is definitely oil mixed in there between oil changes.
2016 4Runner SR5 is offline   Reply With QuoteReply With Quote
