Originally Posted by dvto2
I finally got underneath the car and looked at the lower shaft u joint. It looks worn but not obviously broken. I sprayed some lubricant on it and the steering became smooth again. If it stiffens up again, I'll know what needs repair. Thanks all.
Great game plan....NOT...if the lube made the steering smooth again then obviously you have a bad steering shaft joint. Lube wasn't meant to fix the issue, only to see if it changed your condition. And your condition changed....So replace that thing!
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs |
5th Gen Brakes | Everything else is in the
Build Thread
