View Single Post
Old 10-18-2019, 07:29 PM
83Mule's Avatar
83Mule 83Mule is offline
83Mule is just really nice 83Mule is just really nice 83Mule is just really nice 83Mule is just really nice
83Mule's Avatar
Yes, Moly content levels are no indicator of the oil's quality or wear results as none of these additives should be in play until metal to metal contact happens through heavy lugging or rod stretching RPMs! Long term tests where engines were run on a dyno for thousands of hours to compare synth and dino in the same grade showed little to no advantage to the synth and in some cases a dino actually had less wear! If you don't exceed the normal parameters of an engine's operation you aren't going to exceed even the most basic approved oil's ability to work well.....changing it on a proper schedule is the bigger factor in longevity of the engine.
83Mule is offline   Reply With QuoteReply With Quote
