Originally Posted by XtremeAdventurer
Bought the ‘99 4Runner with 320k miles, so I knew it was going to need some work. After a ToyTec/SuperFlex lift w/ 5100’s, I started to get a lot of stability issues. New SPC UCA, new poly bushings (upper & lower on front, rear, & panhard bar), new steering gear bushings, used 2002 Tacoma steering gear, new CV’s, you name it and I replaced it.
I was also getting a vibration almost like a wheel out of balance and was starting to get a bearing noise. Suspected the front wheel bearing, so I replaced them. The stability problems were gone, but still had the vibration and noise.
Noise started around 25-30mph, vibration started to be noticeable around 60mph and was pronounced at 80. Heaving braking caused a vibration like a warped rotor, but since I had new pad & rotors (Tundra 199 upgrade) I figured it wasn’t that.
I read this thread, checked the Driver CV, and sure enough had a lot of play at the diff.
The video made sense with what I was experiencing, so I ordered the parts & puller and replaced the bearing with the bushing.
I’d say easy as that, but it was a bit of work!
Thanks! Your description of the noises sound a lot like what I have (though I can't remember the last time I had her up to 80
) - will check the noise in 4WD. I don't have any stability issues as far as I know.
I'm running 4600s with OME 880s. As part of a major overhaul when I bought the car, the front bearings, ball joints, inner and outer tie rod ends, rack bushes, anti-roll bar bushes, discs and pads have all been replaced. I'm running newly bought and balanced BFG KO2s.
A friend is coming over here from the US next weekend with my new bush and tool
EO
1993 Hilux 2L diesel manual - in storage.
1996 Hilux Surf 3RZ-FE manual - overland vehicle (and rolling restoration).
1989 Landcruiser BJ60 - undergoing full restoration and engine transplant.
Over 250,000 kilometres around Eurasia in Toyota trucks:
http://eurasiaoverland.com/
