What's mine worth? Insurance Declared Value
Hi, I need to assign a declared value to my truck, for insurance coverage purposes. I can pick any number, but have to be reasonable and have to be able to back it up. In other words, I can't just say it's worth 30k as of today, because then I'll be paying more in premiums (of course) and if something happens to it, they're going to want paperwork to back it up.
I could use the Community's help on this. On KBB, it's probably worth 5k on a good day, but my Ins Co will allow me to value it as I feel fair.
Your input is appreciated, Thanks!
Basic Specs:
2000 Limited, 4wd, locker. 2nd Gen Supercharger (installed 10k ago), 200k miles.
It's had a full maint history, all replacements have been Toyota OEM (not OE or aftermarket or equivalent). I bought it used at 150k, but prior to that, it did have all regular maintenance performed. During my ownership, I did those maint and a lot more. LBJs have been replaced, Rear Axle Seals and a whole bunch of other preventative stuff. Southern Cali Car, ZERO rust. Paint and all panels in mint condition. No Dings, no body damage. Never been repainted. No Leaks.
Maintenance:
Flush Rear Diff 152200
Flush Transfer Case 152200
Flush Front Diff 152200
Replace Air Filter 152000
Flush Transmission Fluid and Filter 152000
Lubricate Chassis/Driveline 152000
Replace Fuel Filter 153450
Flush Brakes 153xxx
Replace Spark Plugs 159656
Clean Throttle Body 159656
Replace Windshield Wipers (F), RainX 160162
Oil Change 161950
Oil Change 170673
Air Filter 172800
Drive Belts (all three, previous alt and AC belt had slight cracking) 172078
Wiper Blades 178000
Oil Change 178500
Air Filter 178500
Radiator Cap 178500
Lubricate Chassis at all Ujoints/driveshaft points 179000
Wiper Blades 183700
Timing Belt, Coolant Flush, Semi Trans flush, Drive Belts (PM), Radiator (PM):
Timing Belt 185800
Crankshaft Pulley Bolt 185800
Idler Roller 185800
Tensioner Roller 185800
Water-Pump (w/gasket) 185800
Thermostat 185800
Thermostat Gasket 185800
AC Compressor Belt 185800
Alternator Belt 185800
Power Steering Belt 185800
Radiator Hose Upper 185800
Radiator Hose Lower 185800
Toyota Red Coolant 185800
Dipstick Tube O-ring 185800
Radiator 185800
Crankshaft Oil Seal 185800
Transmission Fluid 185800
R134 Refridgerant 186208
Oil Change 187200
Wiper Blades 187838
Rear Diff Fluid 189173
Flush Brake Fluid 189173
Transfer Case Fluid 189173
Ignition Coils 189190
Spark Plug Wire set 189190
Spark Plugs 189190
Trans Fluid 189263
Air Filter 189270
Lubricate Driveshafts 189xxx
Lubricate Brake Pedal 190800
Replaced all exhaust nuts and bolts as needed 1908xx
Wiper Blades 196500
Repairs:
Replace Climate Control Lights
Replace Ashtray Lights 152000
Replace cig light with old CC light 152000
Replace Lumbar support (aftermarket instead of OEM) 152000
Replace Rear Drums 153xxx
Replace Rear drums and Shoes 153900
Replace Throttle Cable 159656
Replace Battery with 700cc Super Start Kragen 160162
pre-cat 02 Sensor xxxxxx
Windshield 172000
Tightened Rear Hatch Latch 178000
MAF 179920
Replace Battery Duralast 7xx CC Gold 178950
Rear o2 Sensor 184890
Front Fog Lamps 184950
Front Brake Pads and Discs (Toyota OEM). 185075
GPS antenna 185000
Airlift Pump 185500
Airlift Pump
3rd Brake Light 186208
Driver Heated Seat 187838
Driver Lumbar Support 187838
Rear Brakes Shoes 188116
Rear Axle Seals 189173
Rear Axle O Ring 189173
Rear Brake Shoes 189173
Front Driver Lower Ball Joint 189173
Front Passenger Lower Ball Joint 189173
Valve Cover 189190
Front Grill Clips
PCV and Grommet
PCV hose from engine to PCV 190890
Remote Control Batttery 190900
Liftgate Hatch Struts 190900
Front CV Shafts 191xxx
Front CV Seals 191323
Front Diff Fluid Mobil 1 Syn 75-90 191323
LBJ Flange Bolts 191633
Rear Axle Seals 193024
Pass Axle Seal 193638
Cigarette ring light 193638
AC Controller 196156
AC Backlight 196156
Sunroof 196490
Windshield 198750
Driver/Passenger Seat controls 198850
Driver Side Front Turn Signal Bulb 198875
Starter Contacts 200500
Modifications:
Kenwood DNX5140 152000
Bluetooth
Backup Camera
Sirius
Install Front Heated Seats (extended for driver) 152000
Apex HID H4 4500 Headlights 152000
Husky Liners 151000
Replace Fuel Sender Unit 153450
Sonoran Steel 1.2 Lift 153xxx
BFG KM2 153xxx
Airlift 1000 (25812 with remote pump controller) 60743 bladder
Airlift 1000 (changed bags for better fit) 60763
Replace Rear Diff Label 158800
Install Driver's Assist Handle 158800
Cargo Area LED 158800
Rear Window Switch in Cargo Area 158700
Rear LED Taillights 185xxx
Front HID H4 6000 Headlight BiXenon
BFG All Terrain TA KO2 187890
Airlift Wireless 25870 188116
Wheel Spacers 188xxx
Driver Rear Taillight 188xxx
Diff Breather Rear Extension 188xxx
Washer Fluid Resevoir mod 188xxx
Magnusson TRD Supercharger 189392
IK22 Denso Sparkplugs (x8)
AEM Exhaust Clamp Bung 30-2355-300
Weld Bung onto clamp
AEM 30-4110 AF Guage
AEM 30-4406 Boost Guage
TRD Badge/Blacked Out Emblems
In-Cabin 200w Power Outlet with Inverter
Owners Repair Manual 43155
Tilting Rear Headrests 190900
Warm white LED interior Bulbs 191xxx
Owners Manual 191xxx
6k LED Cougar Motors 196500
Airlift Wireless 25870 196500
Airlift 1000 AirBags 60763 196550
Driver/Passenger Sun Visor with Homelink/Extensions 198900
2000 Limited V6 4WD | Factory Locker | 2nd Gen SC | NGK Spark Plug Wires | AEM Boost/AFM Gauges | Scangauge II | Sonoran Steel 1.2 Lift/Washer Reservoir | AirLift Rear Airbags/Wireless Compressor | 4XInnovations Front/Rear Bumpers | Schrockworks Skid Plates/Sliders | Warn 12k LBS Winch-Synline | LED Halo Driving Lights | LED "Satoshi Cover" Lightbar | Thermal IR Cam | BFG All-Terrain KO2 | Kenwood with Sirius/Garmin Nav and Surround-View Cam | Heated Seats | Lumbar Support | Blacked out Emblems TRD Badge | Rear Diff Breather Extension | LED Taillights | LED 6k Headlights | 120V Power Socket | Flipped Hood and Fuel Release | Rear Window Switch in Cargo Area | Custom FlipBlade Key | Warm White LEDs
