Originally Posted by jhguth
What are you over inflating them in winter, that seems almost opposite of what you would want
Because at negative 20 degrees outside, the pressure quickly drops to where it should be or lower. I set the PSI in the garage; I drive outside. From my garage to the outside can change the pressure almost 10 PSI down.
