Originally Posted by TejasRunner01
Hey
@ Drcoffee
In the quoted method above, how are you repacking the bearing if they are sealed? I'm just trying to figure out from which side you are accessing to repack the lithium grease.
Also just confirming, you are saying to drill a hole in the dust shield in the drum area to drain any possible oil that resides inside?
Thanks!
Sent from my Mi MIX 2S using Tapatalk
The red side plate can be carefully removed, clean out the gear oil and repack with Lithium grease. The bearing isnt very thick. Use a pick and pry off the inner plastic cover. Spray with non chlorinated brake cleaner until the grease is removed and blow out the cleaner with compressed air. Then work in the new grease.
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family-->
I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
