Originally Posted by Drcoffee
The red side plate can be carefully removed, clean out the gear oil and repack with Lithium grease. The bearing isnt very thick. Use a pick and pry off the inner plastic cover. Spray with non chlorinated brake cleaner until the grease is removed and blow out the cleaner with compressed air. Then work in the new grease.
Just to clarify; you're saying the bearing should be removed from the axle to clean and repack the bearing?
Also; why does it need to be non chlorinated brake cleaner?
