Originally Posted by doofenshmirtz
FYI My Anzo lights have clearcoat failure after 14 months of use. For the added cost of the Anzo's over the other cheaper lights, I doubt you get your extra money's worth. I sure didn't. If I could do it over, I'd probably put some kind of protectant on the clear housings.
I used T-taps and heat shrunk the connections to do the halos. The connections they give you in the box don't work as well, and I had issues with them in the rain until I switched to the T-taps.
I was going to use halos from morimoto. I've had experience with them and are pretty high quality but I am also no stranger to tearing cheaper products apart and making them better.
Since this is my first go around with plastic headlights do you have to buff them more often without the clear or did they crack. Just curious.
Sent from my SM-G965U using Tapatalk
98 Toyota 4runner 3rz 5spd 4x4 - Sold
Build Thread
06 4runner 2uz Build
Build Thread
Instagram: @Kryptowerkz
