So for the fronts, everyone is ordering the plain amber and not the switchbacks?
Glad to know as I would’ve ordered the switchbacks instead of plain amber.
Originally Posted by ElectroBoy
1. I don’t understand your DRL setup. Doesn’t your rig use the high beam bulb as the OEM DRL function? Did you change something? If you did, see below.
2. You cannot run these particular Lasfit LEDs constantly On. They are designed for occasional use as turn signals. They take a lot of current and are very bright. They incorporate “CANBUS” resistors across the 12v lines which prevent the hyperflash, but the whole bulb gets really hot after a while, even with their best effort to heat sink the bulb. They apparently incorporate a thermal fuse which opens up the resistor path when they get too hot and they go into a hyperflash mode. I notice this with mine if I put the emergency flashers On for several minutes.
From the Lasfit website:
“Since these bulbs built-in Intelligent Temperature Control, if you use for a long time (a few vehicles maybe 2-5 minutes, it depends on year/make/model and temperature) may happen hyper flash, please turn off and cool 1-2 minutes, they will work properly again.”
3. If your setup is getting too hot you are doing something wrong. Wrong bulb for the application.
