View Single Post
Old 10-25-2019, 09:20 AM
catrains catrains is offline
catrains will become famous soon enough catrains will become famous soon enough
Your problem is the gear gear leaking into the rear drum. do not use brake cleaner because this product has acetone in it and it will destroy all the rubber seals. use mineral spirits to clean it up then check to see after a few days where the leak is ,, use a paint brush in a container with the mineral spirits .. also do the brake pads to remove the gear oil..
replacing the axle bearing on these is not a good day need special tools..possible the axle is worn and the seal cannot work..
catrains is offline   Reply With QuoteReply With Quote
