No sunroof = no leaks and extra headroom.
You are on the right path here. Looks like the 4WD donor is an '00 and that should be nearly 100% compatible with the '99 chassis.
You will need to move the transmission mount crossmember and modify the shifter hole. Otherwise, it is as close to plug-n-play as it gets...
See my thread, linked in my signature for more info/ideas. I stayed auto, but most of the work applies either way.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
