Originally Posted by phattyduck
The cone bumps are there for compression, not droop/extension. With OEM springs, they act as an overload spring to keep the axle off the frame bumps when carrying heavy loads. If you are lifted enough that you don't get close to the frame bump stops or you have extended frame bump stops, then they just act as upper spring isolators.
So you're saying take out the cone supports if I have the extended frame bump stops? Sounds like they both do the same thing and you really only need the bump stops if you're flexing a lot?
Sent from my SM-G975U using Tapatalk
