Originally Posted by TejasRunner01
What is y'all's thoughts on just putting on new shoes since nothing is in the drums as a bandaid until it eventually seeps through the bearing? The bearing is being lubricated currently, the bearing is tight and the abs sensor is magnetic so truly I don't know what it is hurting at the moment. Also.. could this be because I used synth gear oil??
Sent from my Mi MIX 2S using Tapatalk
There is no real outer seal as such. There is the rubber dust boot seal, and the bearing side plate but there is no real oil seal on the outside of the ABS cavity. If you have that much oil in the cavity, you have external leakage or soon will.
Didn't this thread start with you having gunk build up and sticking shoes? Leaking gear oil.
