Originally Posted by KP Texan
OK guys, don't use this design. I had a prototype printed up at the local library; they do ABS and it was only $1! The way it held the microphone worked perfectly, but I had to make some slight dimensional modifications to the base that sits in the OEM mic plate. I'll update shortly.
Just curious, but which Kenwood head unit did you go with? Do the steering wheel controls still work similar to OEM? and is the NAV significantly better vs OEM?
