Originally Posted by billiamwu
What about aftermarket front fenders (not fender flares), specially the McQueen Prototype Design for the 5th gen 4R? They are a slightly different shape, maybe 2" wider, to fit bigger tires. Would the GOAT armor work there/is it pliable enough to get it to fit a slightly different shape?
If not, do you ever do custom work?
Sent from my Pixel 2 XL using Tapatalk
i will say that i bought a roll of the magnetic material, .060 i think, decent heavy stuff. made the same set up for like 90 dollars for the roll. at first i thought it was great but after using it,,, i gotta say, i would not recommend the magnetic stuff for a number of reasons. it does blow off occassionally if you have to get out on a highway for a bit or even a high speed graded road. when it blows off, it will tear usually.
also, it is a real pain to take on and off. plus it is a pain to store somewhere when not using. also, it doesn't protect everything, you will get scratches in between panels.
plenty of other disadvantages as well, just my own experience.
all in all, i am glad i experimented first with my own set, i will be going with the rhino or 3m heat plastic stuff.
