2 things
1. you can adjust the latch tension on the rear door, which is the common culprit for dust getting in.
2. You can also run you heat/AC fan on high, this will slightly pressurize the cabin, and keep the dust seep from getting in.
I always seem to slow down with the my windows down and stop then the cloud catches up..... I try to learn and not do this, roll up windows before I stop.
