Originally Posted by BoomerBob
A little more info to share. The bearing tool worked perfect. Made the job so easy. I work alone 99.9% of the time so lifting the lower cross member to raise and lower it can be a pain so I picked up some aluminum blocks and 4" square plates to take up the space. The blocks can be used flat, sideways, vertical, or stacked along with the 4"x.5" plates.
Hey that's a great idea, where did you pick up the aluminum blocks?
Sent from my Mi MIX 2S using Tapatalk
