Real Name: Elliott
Real Name: Elliott
Rear door grommet part numbers?
So I was running new speaker wire to my amplifier in my 2007, and when I got to the rear doors, I noticed that the rubber grommets are totally trash. They are all cracked and falling apart, so I did my best not to destroy them TOO MUCH getting my wire thru, finished everything up and put some diy loom cover over everything. I would like to replace the grommets, however I can't seem to locate a part number anywhere. Has anyone else run into this situation? Were you able to replace the grommets? Did you find an alternative? Everything I've turned up in search so far only references them as part of a write up, nothing about part numbers or replacement. Any insight would be helpful.
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
