Originally Posted by turbo8
There is also the steering rack guide bushing\bearing.
I believe it originally came with a bearing but toyota changed it to a bushing later on.
YouTube
Yes, the steering rack guide is a good idea.
OP, here's videos related to the subject at hand and maybe one or more will help you figure out your issue.
This video shows you how to swap out your LCA bushings utilizing a bottle jack
This video shows you how to swap out the LCA bushings if you own a press and have bearing splitters and press sleeves at your disposal
This video will show you how to check and fix play in your steering shaft
This video will show you how to upgrade your steering rack guide to the new version Toyota designed.
Finally, if you wanted to swap out your UCA bushings as well, this video will show you one way how to get it done with a press.
