Originally Posted by UnderFire
I've not hooked up the horn or any kind of airbag resistor on mine, I never use the horn anyways and the light doesn't bother me so I'm little to no help. I've seen online some people buying a little flap the rides against the hub's contact, I believe it came stock on a Honda if I remember right but it's been a long time since I read about it.
Sent from my JSN-L23 using Tapatalk
thank you, is this what you are talking about? specifically step 5?
How-to wire JDM horn | Honda Integra DIY
i think i may be able to make that work and it would be a nicer way to do it then what i had in mind. now i just need to find a wiring manual to confirm the white/black wire is the horn/horn ground.
