Originally Posted by 19963.4lsr5
Just so you all know. Running an engine temp colder than 191f will not achieve the 14.7:1 air fuel ratio. It has to be 191 or higher.
I blocked 6” of my rad and I am still running 186-191 this time of year in PA. I’d like to get it to 195. I wonder if flipping the thermostat the wrong way will do it.
Everything I've read has said that it's not very accurate to try and get afr readings off the stock O2 sensor. Not sure what you are meaning that you cant get 14.7 unless you are higher that 191 temp, I have an aftermarket afr gauge and welded bung in the exhaust and bounces around 14.7 ratio well under 191 temp. Am I missing something here? I run a super charger and with a cooler thermostat. Normal operating temps for me is 181. Are you basing your findings on your scan gauge readings?
