Originally Posted by KP Texan
That's great! I didn't get my file dropped off until this weekend, so I actually haven't had the opportunity to test it yet. I would've felt terrible if it didn't work for you, so I'm happy it fit!
I also noticed the same about my SOS light when I had my mic unplugged.
I only had to use a 220 grit sandpaper around the top of the bore to insert the microphone. It was just to tight for the microphone to go through. half dozen wipes with the sandpaper took care of it. I just coughed it up to the tolerance of the print machine used. The high-end printers we have at my office typically result in very slightly oversized dimensions, which is same as undersized bores.
