Originally Posted by Blue4Fun
Help, so I was about to install my lift. I just saw this and it totally screws up my setup. So I was installing the rear Dobinsons springs which are supposed to be 1.5 but apparently their like 1.75.
The 6112 springs only have settings at 1, 1.4 and 1.7 and so on.
So with this theory, if I do a 1 inch lift, I will get 1.5 for the front and have a 1.75 increase in rake from the back. If I go with 1.4, I will end up at 2 in the front and 1.75 in the back almost eliminating rake.
I want to maintain my stock rake and had planed on 1.75 across the board. What should I do? So frustrating.
You are referring the KDSS clip settings with the 600lbs coil, correct?
I am at the 6th clip setting for 2.7” of lift with a 1” Eibach rear coil that is really 1.5” and I have slight rake.
