Originally Posted by DenverTiger504
You are referring the KDSS clip settings with the 600lbs coil, correct?
I am at the 6th clip setting for 2.7” of lift with a 1” Eibach rear coil that is really 1.5” and I have slight rake.
I’m actually looking at the 650lb coils.
I will be installing my Slimline and Warn 10K.
Just found out that the 650lb Bilstein springs has a .5 lift.
I was trying to do 1.75 front and back, but the .5 extra changes that. Either I will be 1.5 in the front or 1.9 (ie 2) in the front. My rear coils will always be around 1.75.
I just don’t know which way to go!
