Having just have the same issue as you described, up to the same spot as leaking I can hopefully offer some advise.
On the nut, the 4th nut is hard to get to, the top left nut. I had to use a swivel connector with a rachet. that was the easiest way to get it out.
I will be replacing the following items for this job:
1. abs pump Motor
2. Accumulator
3. MC piston kit.
To same money, for the pump motor # 1, I'm sending the unit to Eurton Electric for a rewind/rebuilt for around 265.
For the new OEM Accumulator(200 ish) and the OEM MC Piston kit(60ish), you can buy OEM from eBay. you save some money by buying them from United Emirates and shipping seems as fast as in the states. I ordered them on Sat and delivery is Wednesday.
I am hoping that this will fix my issue.
