I haven't adjusted valves since the 1990s on 1980s 22r engines and the last time I did it I didn't have to adjust much.
So like Dogtail asked. Why are you wanting to adjust them?
We dont have a screw driver and nut adjustment anymore like the early 80s 22R did. It all has to be done by shims.
This would be an extremely time consuming process to complete. I can see anyone that would do it have to charge significantly to complete the task.
Also, the participation on this forum is extremely high on all threads. Sometimes nobody has came across a particular issue or nobody does it in the parameters you set.
So stating you begged for help and nobody responded on 1 of your many threads that lots of users contributed on isnt very accurate.
You specifically asked if anyone did it a mile parameter that you selected and the answer was no because nobody activity involved on this forum responded. ;)
Easy wild tiger. We all try through our own experiences to help others on their 3rd gen repairs and maintenance.
Build Thread:
https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer:
https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information:
https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
