XM icon disappeared
I had the same issue happen to me. The XM icon disappeared from my radio’s source screen. All I had to do is open the hood, open the fuse box and remove the radio fuse. I turned the key forward in the ignition switch than turned back off, removed the key. Placed the fuse back in the fuse box located next to the engine. This worked, the XM radio icon appeared again. So in short just remove the radio fuse, turn key to on, than off, remove key, finally connect fuse again and the XM icon will appear. Good luck.
