View Single Post
Old 11-09-2019, 04:45 PM
tristero's Avatar
tristero tristero is offline
Real Name: Justin
tristero will become famous soon enough tristero will become famous soon enough
tristero's Avatar
Real Name: Justin
Originally Posted by tristero View Post
No way you're installing longer bulbs on mine without pulling the lights, I'm pretty jealous that anyone has enough slack to do that.
So I did what @Jeffy said. Installed rear resistors and rear LED. Here's the outcome:
1. LED turn signals work without hyperflash, but I have to use the Lasfit bulbs in the front
2. the nothing fancy, non-CANBUS bulbs hyperflash when put into the front turns
2. DRL no longer works at all with any bulbs
In the rear, I tapped the yellow on LH and light blue on RH for +, as these are the only wires that read on the meter.
Following up: I installed the Morimoto HD resistors. The DRL function didn't work at first but everything is fine now. No idea where the issue was... I checked the wiring and taps several times, then the next day - BOOM - lights work fine.
Regarding the lasfit bulbs, those f*ckers get HOT
I do not recommend for the 2010 to 2014 application
2010 4Runner SR5 Magnetic Gray: Radflo / Icon + Metaltech / Total Chaos / Dirt King / SCS Stealth 6 / BAMF Sliders + Pelfreybilt Bumper / PRINSU / Indel B / 2014+ IS 350 Retrofit
2012 GX460 Premium Black Onyx: Stock af
tristero is offline   Reply With QuoteReply With Quote
